HELP HELP HELP 32GB version netbook android 2.3 netbook
Discussion in 'Android Tablet Q&A' started by swedenmom, Mar 18, 2012.
  1. swedenmom
    swedenmom Member
    I have got this android... downloaded some apps. everything worked great... turned off the machine. Next day turned it on. it says not installed when you click on the icon. I went back to google android market, redownloaded.... same thing again. I bought a new micro sd card... did it again.. same thing again. How do you keep the applications you download? Why am I losing them?
    Regards,
    Swedenmom
  2. Spider
    Chicago, IL
    Hi Swedenmom, congratulations on your new tablet and welcome to the forum. I'm moving your thread to the Android Tablet Q&A section for you, where more people are likely to join the discussion and try to help you figure out what's happening to those apps. Good luck!
