Today, trying to improve my Haipad M701-R I bricked it Any help will be appreciated Basically I tried to flash with a version of the G10 that apparenttly is different . Now it shows the splash screen, then the little green robot, and that's all! I've tried the instructions provided on some forums, but to no avail, in particular there is a step which says that I need to run the Image Creation dialog and then save a nand data file, but I have never reached to that step: all it does is load the files and at the end I get a green screen from FWDN Another question: is the firmware publized here in this forum for the G11 compatible, and if so how can I install it? Thanks
