Help I dont know whats wrong!?!
kyrosgyros
I have a Coby Kyros mid9742 tablet it wont turn on properly. Every time I power it up it starts flickering/flashing the Coby logo and the android logo rapidly and wont go to the home page or the screen goes black still on but completely black or sometimes it boots up perfectly and when go to lift it, it start flickering in and out again. I feel like maybe something may be unbalanced? Like you know how normally when you turn your tablet in certain positions it switches its screen to fit that position well mine starts flickering and flashing and becoming unresponsive. I tried putting on the charger for a while, laying it flat on its back, resetting it, connecting it to a PC but i got nothin
So does anybody out there know whats gong on and how can i fix it?
Spider
15,785
1,813
Hi kyrosgyros, congratulations on your Coby 9742 and welcome to the forum. Nice to have you as a member of Android Tablets. I'm moving your thread to the Coby Generation 3 forum for you, where more people are likely to join the discussion and try to help you. Good luck!
Ricky405jr
255
23
It sounds more like a hardware problem.
Can you give more details how this happened? Did it fall?
Or did you do something with the software?
More details you give, the more people can help you.
