Help me!! v708 vimicro cortex a8/vc882 7inch capacitive firmware
Discussion in 'Android Tablet Q&A' started by rokve, Jul 18, 2012.
  1. rokve
    rokve Member
    Hi! I need your help! (Sorry for my bad English).
    I need the firmware for this tablet.
    http://www.************/es/7-5-point-touch-android-40-8gb-tablet-pc-with-wifi-camera-p-56567.html
    ??ó??
    I lost original firmware and I can not find one that works properly. I have tested with the zixoon v78c firm, wopad 7 and 7 +, many ics and 2.3 and the touch screen never worked.
    Some technical data:
    CPU
    Vimicro VC882 ARM Cortex A8 1GHZ processor
    OS
    Android 4.0.3
    Memory
    DDR3 1GB
    Hard Disk
    8GB
    Storage Device
    Support external TF card, maximum capacity of 32GB
    Gravity
    Fast 4-Dimensional G-sensor
    LCD
    TFT 7" Capacitive 5-Point Touch Screen 800*480 pixels
    WIFI
    WIFI:IEEE802.11a/b/g/n wireless network
    GPS
    Support
    I/O Port
    Headphone *1, TF card reader *1, Mini USB port*1,
    DC Jack *1,HDMI*1 ,2.0USB Port*1.
    Audio
    3.5mm headphone jack
    High-quality stereo loud speaker
    Built-in microphone
    Headset maximum output power of 40mW
    Frequency response:20HZ-20KHZ
    SNR:greater than 90db
    Camera 0.3mpx
    If anyone has any information of the firmware I'll be grateful.
    Thanks!
  2. steviebond2
    steviebond2 Member
    NULL
    I use the same cpu and can say wopad v7+ is what works. Format the sd and load it with the vortex tool. If you need more info let me know.
  3. steviebond2
    steviebond2 Member
    NULL
    Sorry i only just noticed you had 4.03 originally. I had assumed 2.3. Sorry.
  4. rokve
    rokve Member
    Thanks for answering. I tried with the firm of wopad 7+ and the touch screen never worked. Everything else works fine (sound, wifi, etc..), I check with a USB mouse. Do you know how to make the touchscreen work? nothing happens when I touch it.
rom for vimicro 7 inch touchscreen keyboard
cpu vimicro vcsa882
descargar cpu de vimicro vc882 a8
firmware a8 cortex
firmware for 1ghz cortex a8 processor
firmware for vimicro 7inch
firmware for vimicro cortex a8 1ghz 7inch capacitive screen
firmware tab a8 gps
how to identify vimicro tablet for firmware download
need firmware for vimicro cortex a8 1ghz 7inch
recovery rom for vimicro cortex a8 7inch
rom for tab 7inch cortex a8
rom for tablet vimicro 7inch
rom for vimicro 7inc cortex a8
rom for vimicro v802 7inch
rom original for wopad v7
tablet vimicro 12 in
v708 tab rom
vimicro 882 a8 processor
vimicro v708 opened
