Help me with my tablet MID rk2818sdk OS?
caero
I don't know where to get the software or operating system (OS) for update.. help me please:
Specifications:
*Model Number: rk2818sdk
*Firmware Version: 2.1-update 1-1.0.0
*Kernel Version: 2.6.25 lqn@ubuntu #119
*Build Number: V0.18.ECLAIR.eng.root.20101218.120009
These others speifications are got from the web where the i bought
1.CPU:
Rockchip 2818
2. Screen:
7inch resistive full touch screen
3.Operation System:
Android 2.1
4.Resolution:
800RGB*480 16:9
5.Storage:
256MB DDRII, 4GB HD
6.Wireless Network:
1.WIFI:
support
IEEE 802.11b/g
3G:
support WCDMA,EVDO,
TD-SCDMA
7.Micro sd Card Port:
support 128M-32GB Micro sd Card
8.USB Port: MINI 5PIN
9.Sensor:4-Direction Sensor
10.Attaching Plug:
DC4.0mm
11.Earphone Port:3.5mm
12.Microphone:
monophonic recording
13.Speaker: 1W*2
14.Operation Keys: Power on/off, Volume +/-, Reset, Back, Menu,
Home
15.Camera:
1300 thousands pixel
16.Battery:
7.4V/3000MAH Charger: 9V/1.5V17.Size: 204*137*14mm Weight:400g
18.Accessory: manual ,charger,
data line,adapter
Help me please, thanks. ¡caero!
abhigoku10
hey guys i am new to this rk2818sdk tablet with firmware version 2.1 and kernel version 2.6.25 root @zsctc-desktop#208 how to upgrade this or connect to internet its not getting connected to open market it gives error as there is no network connection retry so help me
jacko23
i have jst got 1 too model num sdk demo kernal version 2.6 25 rockchip version 1.2.7 ruiguan still dnt no hw 2 work it or open stuff does it hav sim card mine says that when tryn 2 use google ?
