Help me !!!!!!!!!!!!!!
Discussion in 'Android Tablet Q&A' started by missyjones1974, Jul 9, 2012.
  1. missyjones1974
    missyjones1974 Member
    Warren RI
    CMP738a
    the process android.process.acore has stopped unexpectedly when i turn on tablet and then i can't do anything at all and everytime i push the Force Close it just pop back up what do i do???
  2. Astrix
    Astrix Super Moderator Staff Member
    Singapore
    Public Phone
    You rooted with cwm recovery?
    - If yes, boot to recovery and fix permission.
    Are you using custom rom?
    -If yes, do you flash gapps?
    If all above no..try factory data reset and see how it go.
