Help, My daughter has forgotten her pasword!!!!
Discussion in 'Android Tablet Q&A' started by bhampton, Apr 14, 2012.
  1. bhampton
    bhampton Member
    Ohio
    ainol Novo 7 basic
    Help, My daughter has locked her tablet to keep her brother out of it but now she has forgotten what she made the password. It is a ainol Novo 7 basic. Need to find a way to do a factory reset, just can't find the answers. Thanks
  2. Kackalakin
    Kackalakin Member
    On a device
    Android 2.3 Tablet
    Wait usually on my android if it I get it wrong a certain amout of times it tells me to wait then there are other options like forgot password? Click that then fill it put or type in email
  3. CaptainVimes
    CaptainVimes Member
    Cannock, UK
    Zenithink ZT?
    On my tablet, I have a hole the size of a sewing needle, my manual says that's the manual factory reset button, I would just insert a paper clip end and it would do a factory reset. I have no intention of testing it out! lol :p
    Sent from my ZT ICS using Xparent Purple Tapatalk 2
    EDITED TO REMOVE NEEDLE/PIN AND CHANGE TO PAPERCLIP. (thanks for pointing that out)
  4. jimbo7630
    jimbo7630 Guest
    Top Poster Of Month
    If you MUST use a needle use the BLUNT end, safer to use a straightened out paper clip.
  5. CaptainVimes
    CaptainVimes Member
    Cannock, UK
    Zenithink ZT?
    Corrected my original post, thx.
ainol novo 7 unlock
ainol tablet forgot password
ainol tablet pattern unlock
forgot password on an ainol novo 7
how can we can change password in ainol tab
how to unlock ainol novo 7
how to unlock ainol novo legend 7 tab if we for got our password
how to unlock ainol tablet
my daughter has forgotten her password on her tablet
reset ainol novo 7 lock screen forgot password
