Ok I know everyone will tell me it's my own fault but I tried to install ICS on my slider and it appeared to install with clockworkmod but now I can't get it to come out of the Clockworkmod. It won't boot into the new system.
So does anyone know how to either 1) get it out of clockworkmod or 2) restore back to factory defaults.
I tried the option in clockworkmod to reload factory default and it appears to work but then won't boot to system.
Any help would be appreciated.
Jim
OH well never mind. Reset button on side with the sound - button cold boots. This is interesting to people who don't know because I didn't.
There are 3 buttons on the side of the slider.
1. Labeled 'reset' in manual and is recessed.
2. Sound (+/-) to increase or decrease sound level.
3. Power Button to either turn off or put to sleep you slider depending on how long you hold it down.
Now comes the interesting part.
If you hold the Sound - button and hit the reset button you get an option.
The default if you do nothing is to cold boot into your android system.
The option is to push the Sound + and select Wipe Data and it will wipe your system.
The names of the buttons are in the manual but little else. In my playing around trying to install ICS I have found that everytime I boot my system it come up in Clockworkmod and I can't seem to get it to come up normal. If I do the Sound - and reset and boot to android it comes up normal.
The problem is I can't get the normal reboot to come up in the android system but it always comes up in the clockworkmod.
Anyone that can shed some light on this would be helpful. BTW, ICS appeared to install but really didn't. Once I get my system back to 'normal' I'll give it another try.
JR
Jim
JR
