Help please!
crs_1208
ePad_android16_WMT2.1.1_Factory_Rom.7z
this is the factory rom i got, tried several of tipstir roms but it sends a message:
"could not erase file system. fail! exit! maybe kernel does not support NAND Flash" this shows up..
is there a rom i can use that tipstir made?
mar-yo
13
hi
i have the same problem but i had WMT 2.1.88 and after i applied any rom from forum i got exactly the same comment and now i can't upgrade anything, i can't turn my epad on. when i put power button nothing's happening.
will this factory rom wmt 2.1.1(from post on top) will run on my epad?
or can i find somewhere factory rom WMT 2.1.88????
help me please i don't know what to do...
mar-yo
13
i tried WMT 2.1.1 factory rom (from top) but it says that could not find the udisk!!! and that's it,nothing happens
when i loaded RSX-TYPE-S SCORE OVER-CLOCKING EPAD @ 400MHz WITH WM8505+ a message appears :"could not erase file system. fail! exit! maybe kernel does not support NAND Flash" and now when i turn on my epad there's a message "android 1.6" and that's all, system doesn't load...
help me please....
