Dopo D7016-7 Completely Stops at Android Screen
JimBow
Jan 17, 2017
My DOPO D7016-7 turns on then stops COMPLETELY with the screen "android" showing. It never does anything from there. Please give me some help. Thank you.
Spider
15,785
1,813
Hi JimBow, welcome to the forum. Glad you decided to join us here at Android Tablets.
I'm moving your thread to the Android Tablet Q&A section for you, where more people are likely to join the discussion and try to help you. Good luck!
