help plss urgent :'((
Discussion in 'Coby Generation 1' started by glorymajd, Sep 22, 2011.
  1. glorymajd
    glorymajd Member
    hi I bought coby kyros mid7015 I rooted it and then patched to android gangerbread 2.3.1 but I couldn't finish the rest of the steps 5--->12 it always says device not found :/
    pls tell me what I should do :'(( and thxxx
  2. promek1
    promek1 Member
    Coby 7015, Nook Color, Nook Tablet
    connect your usb cable then mount your tablet to your pc(make sure you see 2 drives pop up on your pc)
    you need to copy the files and drivers and place them on the nand of your tablet Not the SD card. and click on the cmd file
    after each step just copy the .apk and cmd files no need to copy the 3 adb drivers
