Help - USB issues on Epad
Discussion in 'Zenithink ZT180 10 Generation 1' started by mertin_zn, Dec 2, 2010.
  1. mertin_zn
    mertin_zn Member
    NULL
    Hi,
    I have a Android 2.1 OS ZT-180 epad. At present I cannot use any of my USB memory sticks or USB hard drives. The suppliers site mentioned that the epad supports USB 2.0 but no USB devices are picked up by the epad. When I plug in a memory stick the device says " Blank UDISK"
    I also cannot get my USB 3G modem to work. When I plug that it the device says "Damaged UDISK"
    I am a newbie and would appreciate any help
    Marcus
  2. hoben02
    hoben02 Senior Member
    usa
    epad zenithink zt-180
    1) i am using the 1020 rom version on my zt-180 i have no problem plugging in a generic card reader it was able to recognize had to plug and unplug the device a couple of times to get the udisk error to go away.
  3. mertin_zn
    mertin_zn Member
    NULL
    Hi,
    How do I check my ROM version?
  4. hoben02
    usa
    Goto "settings-> about device -> look under firmware version will have a date at the end, 20101020
  5. mospeada
    mospeada Member
    NULL
    Have you tried the USB sticks and drives on a computer to see if they're working? I got a tablet before that had a defective data port.
epad booted longer a-721j
e-pad usb device
epad usb not working
troubleshoot help android epad tablet
zt epad usb port
