[HELP] Vizio Bricked - Stuck in recovery
Discussion in 'Vizio Tablets' started by androidluv, Nov 23, 2011.
  1. androidluv
    androidluv Member
    Vizio tablet
    Hi all, I need some help to try to get my Vizio back to the factory settings. Here is my situation:1 - I attempted to change the fingerprint through an online guide which in turn got me stuck in the stock recovery for the Vizio.2 - I ran a data wipe from recovery - does not help3 - I ran a factory reset from recovery - does not help just boots right back into the screen with the exclamation point from there I can only get into recovery.Options that I can think of (please respond with others if you know any)1 - Reflash the stock system rom from recovery after all that is what recovery is for I thought - but there is no ROM file available (this is beyond me since most companies provide this via download for cases such as these for their customers)2 - Somehow adb in to the tablet and fix the build.prop file with the vizio fingerprint. This would be the easiest but I cannot get my adb to recognize the tablet in the state it is in. If I could just get adb working then I could fix this easily.3 - Is there a way to make a bootable sdcard image to get adb recognizing the device?4 - Somehow flash an alternate recovery and custom ROM - None available at the momentIn my experience with phones and tablets this really is not a bricked device since most have a rom that can be reflashed. That is the most frustrating thing about the Vizio the way they keep everything close to the vest and have not released a ROM that can be flashed.Does anyone have any suggestions? Its probably a good idea to get an unbrick procedure going for the Vizio since I am sure this will happen often with root and all.
  2. bill2
    bill2 Member
  3. rprr
    rprr Senior Member
    Vizio Tablet VTAB1008
    Unfortunately, adb access is not available in the recovery boot.
    PS: Could you please post the website of the guide you followed?
vizio stuck on loading
vizio tablet stuck on loading screen
vizio vtab 1008 recovery mode
vtab1008 recovery mode
