Help with Bricked mid7048-4
Discussion in 'Coby Generation 3' started by Unvariably, Feb 19, 2013.
  1. Unvariably
    Unvariably Member
    California
    Coby Kyros mid7048-4
    Hey guys, I have been lurking in this forum for a while now and finally decided to sign up. I have searching for a way to fix my bricked coby kyros mid7048-4
    So I rooted it and after messing around it started bugging out so I tried to shut it down and thats when it got stuck in bootloop. I reset it and tried turning it on again with no luck. It goes to the Coby screen and then to the android Screen and just sits there looping. I reset it again and put it into System Recovery Mode. I put 7048_Recovery_Root_Gapps.zip 7048_System_Restore.zip and Root_Gapps_Signed.zip on it. When I try to install Recovery and System restore I get:
    -- Install /sdcard ...
    Finding Update Package...
    Opening Update Package...
    Verifying Update Package...
    E:signature verification failed
    Installation Aborted.
    But Root_Gapps_signed.zip works just fine. So can anyone help me out?
  2. Traveller
    Traveller Super Moderator Staff Member
    Coby Kyros MID9742, Lenovo Tab 4 (8"), numerous phones
    On your PC, unzip Root_Gapps_Signed.zip and 7048_System_Restore.zip. Dive into the META-INF folder of Root_Gaps_Signed.zip and look for the following two files: CERT.RSA and CERT.SF. Copy those files to META-INF in 7048_System_Restore and zip up the files into a new archive. Then try installing the new zip.
    • Like Like x 2
  3. Unvariably
    Unvariably Member
    California
    I tried what you said step by step, yet I still get the same error message I was receiving prior. Thank you for looking into it and trying to help me nonetheless
coby kyros mid 7048 recovery zip
how to fix a bricked kyros 7048
mid 7048 bootloop
mid7048 bootloop
