Help with calendar sync.
Discussion in 'Coby Generation 1 Technical' started by code347, Jun 3, 2011.
  1. code347
    code347 Member
    Southern Oregon
    Kryos Tablet
    I just flashed Gingerbread onto this tablet and have been rebuilding my apps. One issue I have come across is that there is no check box to sync the google calendar with the stock calendar. So in turn my Launcher Pro calendar widget is not syncing. I have tried to locate the settings to sync, but they just are not there. Does anyone have a solution?
  2. popeye1128
    popeye1128 Member
    Arkansas
    Coby MID 7015
    Funny, I'm just going thru the fix myself at this moment. It is on tipstirs site. There's like six apks to re-install. Here's the link to the files contacts.rar
    Just install them like any other app right over the top of what's already there.
  3. code347
    code347 Member
    Southern Oregon
    Kryos Tablet
    That's why I love this site...Thanks a bunch!
    Edit: Just reporting back that this fixed the issues!
  4. MarioCG
    MarioCG Member
    Brazil, RS
    Coby Kyros Mid1024
    It worked! Thank you Popeye1128!
    As a note, there was no need to install all files. In my case only theese fixed everything:
    http://www.4shared.com/file/Qrm3v7RP/GoogleContactsSyncAdapter.html
    http://www.4shared.com/file/L0HvUGZ_/GoogleCalendarSyncAdapter.html
    T
    hanks again!!!
how to sync calender on coby kyros mid 1045
sync calendar between tablets
