Help with chinese tablet pc MID 7 inch!!
Discussion in 'WonderMedia WM8505 Tablets' started by manizales10, Dec 30, 2010.
  1. manizales10
    manizales10 Member
    Portugal
    MID 7``
    Hello everyone
    I bought for christmas a tablet from china with a different android than the normal one. I am wondering if it is possible to watch rmvb files in these kind of tablet, because i already downloaded rock player base and nothing happened. Just another question, how to put office files(ppt, pdf,...) in these kind of tablets? When i bought it the seller told me that it had the Android 1.7 version, but i dont think so, because when i boot my tablet it appears 1.9something, and i think that this version doesnt exist from google android.
    I would be very pleased if someone could help me.
    Thanks in advance
    • Like Like x 2
  2. hoben02
    hoben02 Senior Member
    usa
    epad zenithink zt-180
    does it have an external slot for an sd card then you can load them on there
  3. prismblue
    prismblue Member
    philippines
    ePad 7" Touch MID android
  4. hoben02
    usa
    if you can find another rom to reflash the tablet it may have a non-chinese android market
  5. huishell
    huishell Member
    Guangdong China
    NOKIA 5800 XPRESS MUSIC
  6. desfoo
    desfoo Member
    NULL
    you need to convert the files aligning to the correct video & audio codec. if not mistaken, it does not support any higher than 640 pixels. btw, i think your unit is android 1.6 as i m not sure if there is android 1.7
  7. agirezorn
    agirezorn Member
    Deutschland
    MID 10,1 inch
    i have 10. MID android 2.3 and I forgot the security picture for the 3 x 3 points . . . I forgot how to draw it
    I only heart you can do a factory reset, but I don t know how to do it
    someone can help?????
how do i set up my new yuntab mid android tab
how to hard reset yuntab tablet
mid 7 inch tablet driver
tablet l29k
ubuntu l29k
yuntab hard reset
yuntab tablet
yuntab tablet help
yuntab tablet manual
yuntqb
