help with flash player for elonex e touch needed
Discussion in 'Zenithink ZT180 10 Generation 1' started by boylo49, Jan 2, 2011.
  1. boylo49
    boylo49 Member
    hartlepool
    elonex e touch
    i have just bought this for my daughter and most sites she visits need a flash player installing. I am following the steps but come to the part to choose which version, windows or mac,?? tried both and nothing happens. Do i need something different for this tablet, if so what is it and how do i install it? heres hoping...
  2. probbiethe1
    Gilbert, Arizona
    You need to be running android 2.2 and then install the flash app
    Sent from my incredible using Android Talert Forum
  3. xaueious
    Canada
    You can't run full flash on that. It's basically another variant of the Zenithink ZT180.
  4. marie2004x
    marie2004x Member
    london
    android tablet 2.02
    Hi
    did you have any luck getting flash to work? I bought my son one and he needs flash player. been trying for weeks and nothing works so any help would be much appricated thanks
  5. marie2004x
    marie2004x Member
    london
    android tablet 2.02
    Hi
  6. allan40alt
    allan40alt Member
    Rugby, England
    Sony Tablet S 32GB
    Elonex are working on an upgrade for the 1000ET to android 2.2 which will also have Flash.
    The current android 2.1 does not support Flash.
    The YouTube app works well though.
  7. allan40alt
    allan40alt Member
    Rugby, England
    Sony Tablet S 32GB
    It was suggested that I install 'skyfire'.
    I checked this out with Elonex and they confirmed it was compatible.
    I installed it and have now made it my default browser as it plays most (but not all) features that require flash.
    Have a look here to see it in action: Skyfire for Android | Skyfire
    I downloaded it from the app store on my elonex 1000-ET.
    PS: If you go into YouTube there are several demo clips that are of interest. I typed 'skyfire for android tablet' in the search bar and several came up.
  8. allan40alt
    allan40alt Member
    Rugby, England
    Sony Tablet S 32GB
    This is a good demo on YouTube:
  9. markuk
    markuk Member
    Liverpool
    Elnoex Etouch
    The Elnoex eTouch does not support flash. It also uses Anroid version 1.6 which is out of date so may apps and games wont work either :-(
adobe flash player for etouch
compatible flash players for etouch tablets
etouch tablet flash player
flash apps for tab etouch
flash etouch tablet
