Hi, Please help me, I just installed the latest update to my new Iconia A500 tablet which included an update to version 2.0.0.227 of LumiRead. My problem now is that I can't find the settings, there doesn't seem to be an icon on the task bar, other icons don't seem to be visible as well such as the shopping trolley etc. Is it a bad install or is there somewhere that I can find the settings. If it's a bad install, how do I go about re-installing it?
Thanks in advance for any help
docmusic
Have now established that where the icon to access settings, store etc should be there is a row of vertical dots which look like an attempt to render the icon that failed so I now think it's a bad install.
docmusic
