Help with mounting a ext2 partition on 2.2.2
Discussion in 'Huawei Ideos S7 Technical' started by Jota, Jun 23, 2011.
  1. Jota
    Jota Member
    BH, Brazil
    Ideos S7_105
    Hello!
    With Android 2.1 I have 2 partitions on the 8Gb internal sdcard:
    1) fat32
    2) ext2
    I don't use Apps2sd, just have the ext2 partition to do some backups.
    I mount with:
    mount -t ext2 /dev/block/mmcblk0p2 /data/sd-ext
    and it works ok.
    Now, the problem:
    Installed Froyo (2.2.2 Sweden) and I can not anymore mount the ext2 partition:
    # mount -t ext2 /dev/block/mmcblk0p2 /data/sd-ext
    mount: Invalid argument
    I'm trying to find a solution, but nothing seems to work...
    any help??
    Thanks.
  2. tri_zet
    tri_zet Senior Member Developer
    Jakarta
    Huawei Ideos S7
    what about : mount -t ext2 /dev/block/vold/179:2 /data/sd-ext
  3. Jota
    Jota Member
    BH, Brazil
    Ideos S7_105
    Yes, I've tried that... same result!
    In 2.1 both commands work...
    I think 2.2 handles the sdcard in diferent way... could it be?
    Ok, next try is to install recovery, and hope I can mount at boot...??
    Now I must find fastboot for Linux... :)
    (thanks for the tip!)
  4. tri_zet
    Jakarta
    Huawei Ideos S7
    mount at boot time for sure it will work, i use it for data2ext with modified init.rc
  5. Jota
    Jota Member
    BH, Brazil
    Ideos S7_105
    Well...
    I'm new to Android, so I'm learning...
    I thought that the recovery will give me a shell where I could do the mount, but no sir... and, even adb does not work in this recovery... so, still can not get to my ext2 partition!
    I also managed to edit init.rc and do the mount in there, but after reboot what I get is the original init.rc, so my changes does not persist and are lost.
    Any ideas??
  6. tri_zet
    Jakarta
    Huawei Ideos S7
    you have to unpack boot.img
    edit your neccessary init.rc
    rapacked your boot.img
    then flash your boot.img to boot partition using fastboot.
    good example and all necessary tools can be found here : Boot an Android device from SD card
  7. Jota
    Jota Member
    BH, Brazil
    Ideos S7_105
    Ahh, the problem is solved, but not in the way I would like to...!!
    As I mentioned in another thread, I had flashed your most recent Rom, and as you know, your rom has taken over my partition, wipe it and use it for the "data".
    So I lost all my precious files and work... :mad:
    I hate you and your Rom Tri_zet!
    No, really, just kidding, there were just backups and some music files...
    nothing important was lost, so no problem. :)
    And, now I have a ext4 partition, mounted as "data" to play with...
    (as long I don't do a "factory reset", right?)
    One question... why the mount command shows "data" mounted twice?:
    # mount
    /dev/block/mtdblock4 /data yaffs2 rw,nosuid,nodev,relatime 0 0
    /dev/block/mmcblk0p2 /data ext4 rw,nosuid,nodev,relatime,barrier=1,data=ordered 0 0
  8. tri_zet
    Jakarta
    Huawei Ideos S7
    You can do factory reset with no problem now. Factory reset will erase mtd@data and format 2nd partition as ext4.
    Don't ask me why, huawei made it. I pull it from slim boot.img :)
    On first boot (after factory reset) it will not mount mmcblk0p2 yet only mtd@data. so mtd@data have all minimum files to run the tablet.
    on second boot it mount both, so all the change afterward will keep at mmcblk0p2, while the "minimum files" stay at mtd@data.
    I guess this is for preventive, in case it the 2nd partition damage (formatted/deleted/corrupted) it will not got boot loop, but run with 160 MB internal storage only with minimum files just like after factory reset.
    I think you need mmcblk0p3 now, or perhaps mmcblk0p30 to make sure nothing will touch it lol.
    Sent from my IDEOS S7 Slim using Tapatalk
android mount ext2 sd card
ext2 mount android
how to fix data sdext2 mount not found
how to mount ext2 android
how to mount ext2 partition android
how to mount sdext2
mount ext2 android
mountsdext2
sd ext2 not mounted
