Hello. I am looking for a little help with my new rooted nc. First - adobe flash player...its not in the android market. how do I get it.. Second - the book button on the bottom left side that opens your book is not working after I rooted..is that normal...Im using zeam. Thanks!
fisrt - adobe flash player is in the market. It is not supported on your version of android (2.1) - you need to wait for 2.2 second - yes this is normal
Android 2.1 does not support flash, so you can't install adobe flash player on the NC.... for now. The book icon is to go back to your previous book you were reading and doesn't work in a custom launch such as Zeam. My icon doesn't work in my stock launcher either, although I believe some say it does work there.
