Help with Viewsonic Viewpad 10s
Discussion in 'Android Tablet Q&A' started by jojo04, Jun 2, 2011.
  1. jojo04
    jojo04 Member
    singapore
    viewsonic viewpad 10s
    I have just recently bought a Viewsonic Viewpad 10s.
    But I have problem trying to connect it to my pc for file transfer using usb cable.
    My pc wouldn't recognize the Viewsonic Viewpad 10s even when it is plug in.
    Is there any way to solve this problem?
  2. pbrauer
    pbrauer Administrator Staff Member
    Edina, MN USA
    Are you mounting the tablet as a USB device from the tablet side of things before you try to open it on the PC? Check your notification bar and see if there is an alert or a USB symbol, click that and select mount as Disk Drive.
  3. jojo04
    jojo04 Member
    singapore
    There is no alert or any notification on either the pc or the tablet.
    When I connected the two devices using USB cable
    it act as if not ever happened.
  4. pbrauer
    Edina, MN USA
    it is not an alert that pops up, it is something that will show on your status bar. you should at least see a USB icon that shows there. do you have that?
  5. jojo04
    jojo04 Member
    singapore
    no
    nothing happened
  6. jojo04
    jojo04 Member
    singapore
    gave up on trying to figure out on the stock rom
    just installedCorvusVega rom
    the file transfer using usb cable works like a charm
    thanks
