Help
Narelle
I have just received my new tablet and was going through the different sections in the menu and I have somehow managed to get myself into a screen and cannot get out of it, All I have on the screen is a small circle with a cross through it. I cannot get anywhere. I have tried getting back to the main menu and also tried to turn the device off. Can anyone please tell me how to get back to the main screen
Tom T
1,632
191
Probably have to power down the device, press and hold the power button, usually takes about ten seconds. If it has a reset button, usually a pinhole sized opening somewhere on the tablet you can try that if it won't power down.
Spider
15,785
1,813
Hi Narelle, congratulations on your new tablet and welcome to the forum. I'm pretty sure Tom T's advice will work, but I'm moving your thread to the Android Tablet Q&A section for you, where more people are likely to join the discussion and try to help you. Good luck!
