The Pandigital doesn't come with android market so you need to pick up your apps on the net then copy them to the pandigital and tap on them, they will install after you tap the file in file explorer.
slideme.com is one of the other places to get the apps. If you know the name of the app you want google probably will assist. Just google for "appname .apk" and see what you find. (.apk is the extension of all apps)
If one app doesn't install if you find a different version of that app it might work. The Pandigital is a trial and error unit as to apps, some work, some don't.
Before you install much you might want to go to Pandigitals site and run the firmware update and be sure you have the latest version of firmware.
