HiMedia HD900B Android TV Box HD Media Player Review
Discussion in 'Androidinabox.com' started by Androidinabox, May 14, 2012.
  1. Androidinabox
    Androidinabox Senior Member
    Shenzhen, China
    As the pursuit of better visual effects and the trending popularity of networking, HD media players are gaining more popularity in 2012. HiMedia launched the world’s first 3D android tv box media player with the all-new advanced 1186 chip since 1186 chip made first debut.
    HiMedia HD900B Android TV box HD media player features the all-new built-in 1186DD chip. It has much better video / aud​io compatibility and higher radiation capacity than 1185.The key feature is that 1186 chip rides outstanding 3D decoding function and it also sports the updated HTMD1.4 output port for you to experience the perfect 3D visual effects.
    HiMedia HD900B supports parallel HD 3D video playback. HD900B also features HITV2.0 online video playback function which optimized the movie selection, playback, search and other operation steps. Also, the ciphering mode setting is exclusive for Android TV box HD media player only.
    HiMedia HD900B
    CategoryAndroid TV Box HD media player
    StorageBuilt-in SATA hard disk connector, 2xUSB2.0 connects, 1xUSB3.0 connect, 3-in-1 card reader.
    Hard Drives512MB DDR3 RAM
    2MB Bytes Nor Flash; 4GB byte NAND Flash
    Video playbackVideo decoding format: MPEG1/2/4, WMV9/VC1, DivX, H.264, AVC,RM/RMVB,SWF
    Video formats: MTS, M2TS, TS, TP, MKV, AVI, WMV, MPG, MOV, VOB, MP4, FLV, IFO, BD ISO/Folder, DAT, DVD ISO/Folder, RM/RMVB
    3D video layout: left-right, up-down, dual-line HD frame Packing
    Decoding resolution: 480i, 480p, 576i, 576p, 720p, 1080i, 1080p/24Hz, 1080p/50Hz, 1080p/60Hz
    Audio playbackAudio decoding format: MPEG1 LAYER1/2/3, LPCM, PCM, FLAC, AAC, AC3, DTS, DTS-HD
    File format: APE, FLAC, MP3, WAV (PCM/DTS), OGG, AAC
    Audio source format: DTS, DTS-HDMA, TUREHD, Dolby Digital, Dolby Digital Plus
    Photo browsingJPG, BMP, GIF, TIFF
    OthersDisk format: BD, AVCHD, DVD, VCD, CD
    SubtitleFormat: PGS, SRT, SUB, idx+SUB, SSA, SMI
    Decoding: UNICODE, ANSI, etc
    Supply power12V/3A
    Other featuresCPU: Realtek 1186DD SoC, 1200 DMIPS MIPS Processor
    Video connectorHDMI 1.4, CVBS Composite video, YPbPr
    Audio connectorLeft and right stereo, SPDIF digital optical fiber, SPDIF Digital Coaxial
    Input connectorCable network: 10/100/1000M
    Wireless network: Built-in 802.11N Wi-Fi
    Size226×180×50mm
    Beautiful Design of HiMedia HD900B Android TV box
    HiMedia HD900B Android TV box HD media player adopts the gorgeous appearance of previous 600 series. HiMedia HD900B features beautiful outer frame with metal drawing technology and mirror finish front panel. Although having the same metal frame with HD600B, HD900B sports incredible specifications and features.
    HiMedia HITV2.0 features exclusive web design and channel navigations. All the online video types – movies, TV shows, animations - are categorized by the channels. The easy-to-use operation makes smoother user experience.
    The super search is another highlight of HiMedia HITV2.0. You can just input the capital letter to search the movie you want. Now you can ignore typing on the remote control, and just put in the capital letter.
    HiMedia HD900B TV box media player initiated the continue-to-play feature for your favorite shows. You can easily add favorite tv shows to the folders and create your own library. The added videos feature Intelligent Memory function and support continuing break point transmission.
    Besides, HiMedia HITV2.0 also supports exclusive function like drag-and-drop playback, online selection, pause and buffer. As the first 3D media player, HiMedia HD900B media player brings not only the new product, but the new 3D era to all of us.
    Vivid online experience
    HiMedia HD900B Android TV box features the newest Realtek 1186DD CPU and supports the advanced 3D super HD video decoding technology. It also rides HDMI 1.4 super HD connectors for 3D video output. At the same time, HiMedia HD900B features 36-bit colors and 1280P decoding. The excellent video effect and the fine-and-smooth pictures will bring you the lifelike and amazing experience while watching the movies. Also, the video and audio are always synchronizing and clamping stagnation will never happen.
    Subtitle
    The advanced subtitle feature on HiMedia HD900B Android TV box is fully revealed. Many subtitle formats are supported: SRT, SUB, idx+SUB, SSA, SMI, UNICODE, ANSI, etc. You can set up the subtitles, audio, jump-point play and other preferences.
    UI interface
    HiMedia HD900B HD TV box adopts navigation interaction user interface. All the movies are listed in the form of wall posters. It allows you to select the films you’d like to watch quickly.
    With the outstanding HiTV2.0 online platform, you have much more choice while booting the HD900B. You can choose whatever you like to watch. HD900B Smart TV Box media player gets rid of the problem of film sources and brings you the 3D experience like never before. All the annoying advertisements are thrown away. Your favorite variety show are all updated in time and synchronizing with tv programs. You won’t miss your favorite tv shows again!
android tv box avchd
apps for himedia box
himedia hb900b
himedia hd 900b
himedia hd900b
himedia hd900b review
himedia hd900b specification
himedia tv box review
how to use a himedia android box movies search
how to use android app on himedia hd900
