HIPSTREET FLARE ... setting up EMAIL " HELP "
jansenga
Apr 27, 2014
I have read the manual and I have watched numerous videos but I cannot seem to get the email set up on my husbands new tablet. The videos show a step that doesn't appear on the tablet as I follow along, in the end I always get a message "couldn't open connection to server" I hope someone can help me. :confused:
leeshor
6,330
1,037
Welcome to the forum
Lots of info missing from your post or I could have provided a link. Whatever or whomever your provider is for your mail and depending on if you want to set up POP or IMAP mail do a Google search using the following words - POP (or IMAP) settings (your mail provider's name) android. Ignore the ( and ) that was for clarification purposes.
jansenga
Apr 27, 2014
thanks ... I have watched the videos (from different sites as well as the one you recommended) and I follow the steps but they show a screen that does not appear when I do as instructed ???
jansenga
Apr 27, 2014
So sorry (newbie and nervous) our service provider is TELUS ... I should mention I have tried the option MANUAL SET UP and entered the information I have regarding incoming and outgoing POP etc and I am still hitting a brick wall. As I mentioned when I follow the video it shows a screen that does not appear on my tablet as I go thru the steps :(
leeshor
6,330
1,037
The videos I've seen don't cover all the possible configurations used by all the mail servers. Do a search using either "POP" or "IMAP" and the words settings Android and the name of your mail service. Don't use the quotes.
Musing
216
41
Thank you Jansenga, for letting us know that leeshor's recommendation worked. :)
