Rooted using xboxepert instructions, want to return to stock but confused on his instructions, step 6 says. Step 6: Reboot (Choose Yes to disable recovery flash and when asked if you want to root you can choose yes if you want to add the su bianary - see step 7) What happens if you choose " Yes" will it install the original Recovery?
Choose Yes to disable recovery flash What happens on the first one "Choose Yes to disable recovery flash" is recovery flashed CWM? Or stock
