Honeycomb Build For Kyros
Discussion in 'Coby Generation 1 Technical' started by hankm24, Nov 5, 2011.
  1. hankm24
    hankm24 Member
    Coby kyros OEM2.3 with Root ! and my Froyo Rom
    Hello and thanks for taking the time to read this thread. I have managed to make a rough port of honeycomb(actual android 3.0) to the coby kyros 7015 & 7022. How I did this is i extracted all the files from my xoom to my computer and merged them with the kyros files. Sure lots of things don't work like WIFI, Video, and HDMI, but I have time to fix that.EDIT- Fixed WIFI now Here are some screen shots :[​IMG]
    [​IMG] GO to hackingeverything.tk to get the build make sure you're rooted and have clockworkmod installed
    • Like Like x 4
  2. Asgard
    Asgard Member
    KYROS 7015A
    Nice work.
    Good luck!
  3. burghman
    burghman Member
    Pittsburgh, PA
    Coby Kyros 7015
    Sweet! I'm going to try to upgrade tomorrow. Thanks for putting it together!
    Sent from my MID7015 using Android Tablet Forum
  4. shiroken11
    shiroken11 Member
    Coby Kyros 7022
    Uh, I can't find the files? I'd love to try this on my 7022!
  5. mrbean1957
    mrbean1957 Member
    Independence Mo.
    Coby 7015
    Well did you get it installed?
    • Like Like x 2
  6. superslayerman
    superslayerman Member
    Utah
    Coby Kyros 7022
    I cannot find the build files. Please help. I would really like to test it out.
  7. LiquidFire187
    LiquidFire187 Member
    California
    Polaroid PMID701i
    How is the port going? I'd really appreciate an Update! I'm thinking about getting a Coby Kyros MID7127 and wondering if anyone has tried this with it or if it will work..? Thanks!
  8. not12listen
    not12listen Member
    sf bay area, ca
    Coby Kyros 7022
    i'm really interested to see if this is a working build or not... i mainly use my 7022 to watch videos. so, if that doesn't work, then i'll have to pass...
    thanks!
  9. TheDroid13
    TheDroid13 Member
    Minnesota(home of the nothing)
    Coby Kyros 7022
    Come on man:p I really appreciate that you took the time to put this build together, but in order to be a respected dev here, you have to support your work. It isn't fun to get excited and be disappointed by being unable to find the build.
  10. shiroken11
    shiroken11 Member
    Coby Kyros 7022
    Please, where are the files? I would also like to test this out on my 7022! :)
  11. theplague
    theplague Member
    Hi, can we get access to the files to test the custom rom?
  12. vampirefo.
    vampirefo. Senior Member Developer
    Huntington WV
    Leagoo Lead 1 ZTE OPEN C, Coby 7065, Coby 8042, Coby 9740
    I doubt this would work, the deivces are too different, the files couldn't be merged.
coby kyros mid7015 update honeycomb
