(HOW TO) Bootable CyanogenMod SD Card for Nook Tablet
Discussion in 'Nook Tablet' started by J515OP, Mar 12, 2012.
  1. J515OP
    Northern CA
    This thread contains the instructions for creating a bootable SD card for running custom CyanogenMod ROMs. This leaves your internal device alone if you want don't want to root it or install a ROM over it (and preserve the warranty).
    Resources: http://forum.xda-developers.com/forumdisplay.php?f=1397
    • Like Like x 2
  2. Cahill84
    Cahill84 Member
    Where are the instructions? I'm not seeing them?
  3. candyman2012
    candyman2012 Member
    SC
    Nook Color, Novo7 Advanced
    does this information exist on this forum? I keep looking and finding dead ends or old info or link to buy N2A cards
  4. J515OP
    Northern CA
    Sorry about that I intended to have this organized similar to the Nook Color. Unfortunately I have been unable to get to this as a side project. On top of that the resources for the Nook Tablet have never been as available or organized as for the Nook Color which would have required even more effort to pull it all together.
    The resources are out there and the Nook Tablet is as easy to work with as the Nook Color at this point. Both move very quickly since they are popular with the developers and it would be impossible to keep up with all of the changes on this site by myself. I have updated the OP with the XDA resource though. Feel free to explore and then share what you find here for others since XDA is for the tech savvy.
    JP
  5. drcameron
    drcameron Member
    United States
    Nook Tablet, Ivie 754tpc
    Make the NT rock and install Jelly Bean boot via microSD in 10 easy steps:
    1) Format a good SD card of at least 4GB in size (A good SD card should have a formatted Crystal disk 4k QD32 write of 1 or greater.) I found the 16gb G.Skill Cl10 cards from newegg were great - QD32 1.4.
    2) Download the rather stable cm10-121208_acclaim_sd_hd_img.rar and extract the image file using 7-zip.
    3) Write the extracted image to the SD card using win32diskimager. Make sure you are writing to the SD card and not to some other portable drive or SSD on your PC!
    4) Open MiniTool Partition Wizard and you should see your PC's partition(s) (leave these alone) and 5 partitions including the unused partition on the microSD card.
    5) Delete Partition 4 (Fat 32 SDCARd) and hit Apply
    6) Delete the Other partition ~600mb and hit Apply (Neither of those two partitions had any files in them. DO NOT delete the 1st or second partitions which both have the necessary files already inside.)
    7) Create a new partition called DATA and select Primary and Ext 4. Make the size 1-4GB (or more) depending on app usage. This is where apps will install. It you are an app hog, them go with 4GB. I went with 2.5GB. Hit Apply.
    8) Create a new partition called SDCARD and select Primary and FAT32. The size should be the remaining card space by default - leave it this way. Hit Apply.
    9) Close the Partition Wizard, remove the microSD card and place it in the NT that is currently turned off (it needs to be off and not in the sleep state).
    10) Turn the NT on and welcome to Jelly Bean. (If you reboot it will go back to stock NT. If you turn it off and then on it will boot Jelly Bean.) Enjoy!
    Note> some NT's need to be plugged into a powered usb in order to boot to an sd card.
    Thanks go to:
    CM10.0 Jellybean SDCard IMG for Nook Tablet (12/08) « iamafanof
    How to Guide: Bootable (CM7/CM9/CM10) SDCard for Nook Tablet « iamafanof
    What is the fastest SD card you can buy for the Nook? - xda-developers
    Nook Tablet 1.4.3 complete root guide for 8or16gb to GB and JB - xda-developers
  6. MrBookworm
    MrBookworm Member
    Nexus 10, Nook HD+
    Drcameron, thanks for the instructions. Exactly what I needed!
boot android from sd card nook tablet
boot nook tablet from sd card
boot tablet from sd card
bootable sd card android tablet
how to boot a dead nook color
how to install kitkat on a dual boot micro card
how to make sd card bootable for android tablet
nook bootable sd card
nook color install cm10 on sd
nook tablet bootable sd card
