How to customize Bluetooth headset button on Note 8.0?
Nov 2, 2013
Hi,
I just purchased a note 8 and a Jabra headset (BT 2046), but I'm not able to customise which sound recognition app launch when I push the headset button! (The default app is S voice which works online). How can I do that?
P.S : I downloaded Bluetooth button controller which also is not able to customize my headset button!
Nov 2, 2013
Hey guys,
I found the answer, if you go to the settings and
Settings-> application manager-> all-> s voice -> Disable
Then when u push the headset button, a list of compatible apps pops up which u can choose from that list.
I would be gratefull if someone could suggest some usefull offline voice recognition apps
Sent from my GT-N5100 using Tapatalk
