How to disable constant chime sound
hugtree
When I boot up my Vizio android tablet it starts to make a chime sound and does not stop after it is completely booted up, cannot figure out why it is doing this and the only way to stop it is to restart the tablet....anyone know what's causing this or how to disable it I don't want to have restart the tablet twice every time I want to use it. Appreciate any help with this.
Wendy
J515OP
Super Moderator
5,172
899
Hi Wendy, have you tried a factory reset? That is probably a good place to start.
Deandec
57
Perhaps going into Settings and observing which apps are running after startup will identify one that is causing the chime to occur. Then force stop that app?
