The title says it all... ,I read about an app that help u save but I forgot the name. Sure someone can help Gloria
Hi Gloria I think you want to check out this thread http://www.androidtablets.net/forum/nook-color-technical/5119-setcpu-settings-nookcolor.html in Nook Technical which can be found under the "useful links" sticky at the beginning of this main forum. -JP
Not sure if it's the one you're looking for but 'setCPU' which is available on the Market allows you to create profiles that underclock the nook so it draws less power during times the nook is asleep or not needing much power.
Thank you Jp and Facemam, I recognize the name and I remember someone saying not to mess with the advanced setting unless you know what you r doing....I surely dont but I will mess with it, with your help of course! Life is not for the faint at heart! gloria
And don't forget the backlight. It's wonderfully bright, but only needs to be at 100% on the beach. In typical indoor lighting, I find that 30-50% suffices. About 15% in dim lighting, and 5% when the lights off. Saves juice bigtime.
Thank you to remind me...right now I turned it down completely....I want to get that app that gives one control of the light from the main screen. I did set.cpu following Rico insructions,thank you Rico, and I think today, doing exactly what I did yesterday, I'll get one more hour out of my battery and that is good! Gloria
If you did the SetCPU profiles and turn your screen brightness down, you will probably be pleasantly surprised with 4-5 more hours of use.
I did the setcpu thing yesterday and took it off charge when I left work at 4:00.. It's sitting at 51% charge right now, and I played with it all evening yesterday and didn't power it down overnight. Battery Left tells me that the total battery life is going to be 16:46.. Impressive!
I use Brightness Profiles. It has some built in profiles, but I created custom profiles for different lighting conditions, so I can quickly tap the best lighting for each situation. Usually quite low, but more than adequate. Last night, just before I went to sleep, I decided to check out 100% blacklight in a darkened room. OMG that is bright - I think I blew out half my rods and cones. I could have held an indoor lacrosse game in my room. Anyhow...
Make sure you've turned off the cell standby and telephony services as indicated at this link: [SCRIPT] Remove Cell Standby Service (Super Battery Life!) - xda-developers After I rooted my nook, the battery lasted about 10 hours. After this mod, it now lasts for days.
Can you summarize the steps to do this? That thread is 13+ pages, and people are arguing about it the whole time.. What exactly worked for you?
RaVeny.I must br still doing something wrong ..,with Cpu and brighrness widget that let me dim fast from main.screen ,I get. 5 hours of non-stop of internet surfing. You think is good,?
As previously asked, can you be more specific about your process with this. Their thread has a bit of back and forth.
How much junk do you have installed? I went through mine and smoked everything I had downloaded, ran once and forgotten about. That was quite a long list-o-junk.. Before that, the life was fairly brief, which is what prompted my interest in underclocking. Following Rico's screens and cleaning out the junk, I got almost 17 hours before I needed a recharge. That's pitiful compared to days, but pretty good compared to the 5-6 hours I was getting before. I'm very interested in MMMichael's answer..
