How To Get Auto-Rotation For Nexus 7 Home Screen And App
Discussion in 'Nexus 7' started by RedDeer, Aug 4, 2012.
  1. RedDeer
    RedDeer Member
    SpaceStation, Space
    One of the problems with the Nexus 7 Tablet is that the home screen does not rotate from the portrait mode. (same for app tray)
    If you have your Nexus 7 on a stand, this can be a problem.
    Checking around the internet, I found two solutions. One cost $3. The other is free.
    1) Use the Ultimate Rotation Control App. It costs $3.00 to keep. (Free to try for 7 days) At the PlayStore.
    2) The free method requires you to root the Nexus 7 first. ... See the easy root discussion here XXXXX
    Once you are rooted, you need to download a root explorer.
    ... The Root Explorer (free Version) at http://www.1mobile.com/root-explorer-94072.html
    ... The ROOT Explorer Lite App is free and will do the job. (from PlayStore)
    Basically, you need to edit the Nexus 7 *** build.Prop *** file
    1. Open your root explorer app
    2. Navigate to the build.prop ( system/build.prop )
    3. Press and open the build.prop file the the explorer's file editor
    4. Scroll to te bottom end for the build.prop file and add the following line
    launcher.force_enable_rotation=true
    Save the build.prop file. Restart your tablet.
    Now your home screen should auto-rotate from portrait or landscape. (App tray too)
    Good Luck
  2. Frederuco
    Frederuco Super Moderator Staff Member
    /EARTH/USA/NC/
    ASUS TF101
    And an easier solution: Get Apex Launcher or Nova Launcher. Both of those allow rotation.
    Another way is to modify the LCD Density in the build.prop from 213 to something 170 or below and it will get the classic Tablet UI with the clock/notifications in the lower right.
  3. Angus66
    Angus66 Senior Member
    OH
    Acer A700, Nexus 7 FHD
    Any downsides when changing the LCD Density from 213 to 170???
  4. leslieannehope
    leslieannehope Member
    Canada
    Nexus 7, Xoom
    It makes a lot of fonts and windows smaller. I couldn't find any way to increase some items and went back to the standard LCD Density of 213.
  5. jgumphress
    jgumphress Senior Member
    Arlington, TX
    Nexus 7 2nd Gen. and Samsung Galaxy S4
    Get the app called Rotation Control by FaMe IT. It works with the stock browser and works very well I might add. You can set it to rotate depending on your preferences. I set mine to rotate to every turn.They have a free (limited time) version you can try out but the app is only $1.99. I don't mind paying for good apps. On a side note, if you want to read SD cards or flash drives get the Nexus Media Importer by HomeySoft.
  6. Angus66
    OH
    I use the Rotation Control app on my N7 as well. It works great and is well-worth the price in my opinion!!!
  7. Natey2
    Natey2 Senior Member
    California
    Nexus 7, iDeaUSA CT702/YG A777
  8. jgumphress
    Arlington, TX
    The new software will have the auto-rotate included. Now that I spent $1.99 for an app to do it.
  9. Natey2
    California
    Thanks! I just OTA updated to JB 4.1.2, and the homescreen rotates fine without the need for a 3rd party app.
    Sent from my Nexus 7 using Tapatalk
  10. johniii
    johniii Senior Member
    thanks but i can wait for the OTA update
  11. billynibbles
    billynibbles Member
    West London
    Nexus 7 16gb, Arnova 7 G2
    Hopefully, you'll have the update by now.
auto rotate build prop
autorotation in root explorer
nexus 7 2013 rotation problem
nexus 7 auto rotate
nexus 7 auto rotate fix
nexus 7 screen auto rotate
nexus 7 screen rotation app
nexus 7 tablet auto rotate
rotation problem in nexus 7 2nd gen
screen rotation build
