How to unmount an USB flash drive?
Discussion in 'Lenovo IdeaTab A2109 Technical' started by a2109a, Jan 28, 2013.
  1. a2109a
    a2109a Member
    Lenovo IdeaTab A2109A
    I connected an USB flash drive with an OTG-cable to the A2109A. The flash drive is mounted, but how do I unmount it? There should be another way than doing it in a shell.
    Code:
    root@android:/ # mount | grep storage
    /dev/fuse /storage/sdcard0 fuse rw,nosuid,nodev,relatime,user_id=1023,group_id=1023,default_permissions,allow_other 0 0
    /dev/block/vold/179:49 /storage/sdcard1 vfat rw,dirsync,nosuid,nodev,noexec,relatime,uid=1000,gid=1015,fmask=0702,dmask=0702,allow_utime=0020,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro 0 0
    /dev/block/vold/8:1 /storage/usbdrive vfat rw,dirsync,nosuid,nodev,noexec,relatime,uid=1000,gid=1015,fmask=0702,dmask=0702,allow_utime=0020,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro 0 0
    Code:
    root@android:/ # umount /storage/usbdrive
    Code:
  2. leeshor
    leeshor Senior Member
    Norcross, GA
    Samsung Galaxy Tab S 10.5
    Look in settings - storage and see if the option to unmount is there.
  3. a2109a
    a2109a Member
    Yes there is an unmount option there, but it reboots the tablet and afterwards it is mounted again. So it is useless. It is better to turn off the tablet and remove the flash drive.
    Honestly, if you aren't reading from or writing to the drive I would just remove it.
  4. arbarnhart
    arbarnhart Senior Member
    nc
    lenovo a2109
    I used the option in settings the first time I did this, but I have been just removing it since then with no problem.
  5. sid9921
    sid9921 Member
    Its very simple drag down the notification panel and click on "USB mass storage connected" under ongoing section
  6. Music
    Music Senior Member
    Northcoast, OH
    Google Nexus 7-13, 32 Gb
    In the old days, you needed to reboot the device after connecting a peripheral, and before disconnecting it. The OS usually closes any connections to the device before shutting down, so that IMO, would be the safest way to go. Otherwise, contact the developer of your application and report the problem- it shouldn't be rebooting just from unmounting the OTG device.
android how to unmount usb
android unmount usb
how to unmount otg android
how to unmount usb android
how to unmount usb from android
how to unmount usb from android tablet
how to unmount usb in android
unmount usb android
unmount usb storage android
unmounted usb
