hello every one I need help my tablet is haipad MID 701 4GB i know there is a firmware support Arabic language as well actually it support all that languages: Arabic (Egypt), Arabic (Israel), Bulgarian, Catalan, Croatian, Czech, Danish, Dutch (Belgium), Dutch (Netherlands), English (Australia), English (Canada), English (India), English (Ireland), English (New Zealand), English (Singapore), English (South Africa), English (United Kingdom), English (United States), Spanish (Espana), Spanish (Estados Unidos), Finnish, French (Belgium), French (Canada), French (France), French (Switzerland), German (Austria), German (Germany), German (Liechtenstein), Greek, Hebrew, Hindi, Hungarian, Indonesia, Italian (Italy), Italian (Switzerland), Japanese, Korean, Latvian, Lithuanian, Norwegian, Polish, Portuguese (Brazil), Portuguese (Portugal), Romanian, Russian, Serbian, Slovak, Slovenian, Swedish, Tagalog, Thai, Turkish, Ukrainian, Vietnamese, Complex Chinese, Simplified Chinese and a sow the pic. and I found that on aliexpress Wholesale Free SHipping telechips 7 inch google android 2.1 / android 2.2 tablet support Arabic / Thai can any one tell me where to get that firmware ?? thank you
I found this over at xda-developers: Locale & Language Support in G1 Android - xda-developers The thread discusses adding font support for Thai and Vietnamese, but should work for any language with a non-western character set. It appears if you have the font set for a language you can swap out the system fonts for it with ADB. I believe that would let you read and write in that language, but doesn't do anything for "localization" (that's where it swaps out strings, names, views, etc., for translations into the native language setting on the device but only works if the app was written to support localization and the firmware supports setting it to that language, which swapping out the fonts wouldn't do). I'd assume that, much like apps, the operating system itself has a localization files for some other languages (I'm guessing they'd be framework files). It suggests, anyway, that you can modify an existing firmware install to support other languages at least to some extent.
Thank you Offworld for your replay But not that what I want actually I fix the problem with replacing that files DroidSansFallback.ttf, libwebcore.so in the folders system/font system/lib After rooting my M701 And it works fine "not super fine" but I still want the firmware I show in the screen shot Thanks
Is your tablet authentic haina M701 or clone one? They use different nand flash, so firmware are different, i have both, but i do not wanna give you wrong firmware.
hi fancyui I really do not know but I was able to update my tablet with the http://www.androidtablets.net/forum/telechips-based/5911-new-m701-firmware-avaliable-haipad-20110111-a.html so i think it's authentic haipad MID701 HY 4GB thank you
Hammda, i need your help I've got a haipad M701 and can't add Arabic fonts to system. Pls help my firmware is MID 2.1-update1, 2.6.29 root@localhost #133 Build MID1.2 Would you please explain step by step?
I found xflytouch 256.1.9.88 v4a 7z 1.9 for my tablet and have saved it to my sd card but from there how do i install it on my Mid 7 tablet. When i go to file browser and locate file it just come up with copy, cut, paste, rename and delete, properties and select all.. what now. New to tablets so a little lost. Any help is appreciated Mel
hi fzakri This easy 1st you must make your pc recognize your tablet by doing this 2nd downlode that file form here Multiupload.com - upload your files to multiple file hosting sites! 3rd in your tablet go to settings then Application then mark Unknown sources after that in the same place go to Development then mark USB debugging 4th go to the file you downloaded extract the file in your pc and but it in root c:\ make sure that you get the folder ar in root c:\ connect your tablet to your pc by USP go to start the Run and type cmd you well go to DOS window there you have to type this cd / cd ar adb devices then you well see 2 lines the lower one with numbers if you can see that that's mane your adb works fine if you cann't see the numbers in the lower line go back to step one now type arabic now your pc going to transfer the files to your tablet after that your tablet gonna reboot you can now disconnect your tablet form USP now you have root and Arabic font you can brows Arabic web sites hope it was easy good luck
