i need help here please
Discussion in 'Coby Generation 3 Development' started by acidburn23, Dec 30, 2012.
  1. acidburn23
    acidburn23 Member
    Philippines
    Coby Kyros Mid7048
    I'm done to install the custom of 8048 for my 7048 again then i wipe data and wipe cache and install the custom rom and I check the storage the 2nd internal memory said insert for mounting? I'm done to mount data thru cwm and the nand I can't format and mount,,,, but the from is good 4.0.4
  2. acidburn23
    acidburn23 Member
    Philippines
    Coby Kyros Mid7048
    the 8048 have no camera driver? i try to download from playstore but the msg said theres no camera in my device? so no choice restore again to stock rom
  3. Traveller
    Traveller Super Moderator Staff Member
    Coby Kyros MID9742, Lenovo Tab 4 (8"), numerous phones
    Why are you attempting to install items for an 8048 onto a 7048? It's not going to work. First of all, the most obvious difference is the screen. The size is different, which means the hardware is different, which means the drivers are going to be different. It's the same issue with the camera and quite possibly the internal memory spaces. The only thing the two units share in common are ports and the Telechips CPU.
    Restore your tablet or you'll brick it, if you already haven't.
