I need help!!!
Discussion in 'Gome Flytouch Problems' started by igoru, Nov 16, 2010.
  1. igoru
    igoru Member
    Ukraine Kiev
    Good afternoon! Last month I have got Google android Tablet.?????? 12 days it have ceased to work.
    It isn't loaded: at inclusion there is an inscription: ANDROID_ Further it hangs. Tried to use button RESET, but also it doesn't work, all is simply switched off also... HELP PLEASE!!! WHAT to DO?THANKS!!!
  2. pbrauer
    pbrauer Administrator Staff Member
    Edina, MN USA
    Can you please provide specific model information
    If your device has a removable battery, please turn the device off, remove the battery, then reinstall the battery and power on the device to see if that resolves the issue.
    Also, did you install any new applications prior to your device having this issue?
    • Like Like x 2
  3. igoru
    igoru Member
    Ukraine Kiev
    Model 10.2 "ePad Google Android 2.1 WiFi Tablet PC + 3 Gifts is all the information about antivirus ustroystve.Ustanavlival through market.Ustanovochnogo drive was not, USB cable and battery net.K not have access.
    Thank you for your response and responsiveness;)
  4. igoru
    igoru Member
    Ukraine Kiev
    Model 10.2"ePad Google Android 2.1 WiFi Tablet PC + 3 Gifts is all information on the device. Established an antivirus through a market. An adjusting disk wasn't, USB the cable also isn't present. To the battery there is no access.
    Thanks for the answer and responsiveness;)
  5. hoben02
    hoben02 Senior Member
    usa
    epad zenithink zt-180
    • Like Like x 2
  6. igoru
    igoru Member
    Ukraine Kiev
  7. igoru
    igoru Member
    Ukraine Kiev
    Has made all under the instruction, ALL WORKS ;). is grateful to ALL
