(Info) Nook Color Full Specs
Status
Not open for further replies.
J515OP
Super Moderator
5,172
899
Nook Color full specs:
  • PCB: Foxconn ML1 S 94V-0
  • CPU Processor: ARM Cortex A8-based Ti OMAP 3621 @ 800 MHz (same processor as Droid 2 and Droid X)
  • GPU Processor: PowerVR SGX530 Graphics Rendering: Open GLES1.1/2.0 Hardware Scaling: 854x480 scaled to 1024x600 Video Formats: .3GP, .MP4, .3G2 ** Video Codecs: H.263, H.264, MPEG-4, ON2 VP7 ** Image Formats: JPEG, GIF, PNG, BMP ** (same GPU as Droid 2 and Droid X)
  • RAM: 512MB Hynix H8MBX00U0MER-0EM MCM (Stacked Chips 2x256MB each die mDDR)
  • Internal Flash: 8GB Sandisk SDIN4C1-8g
  • Removable Flash: 32GB via microSDHC
  • Radio: Chip ID Ti wl1271 (kernel reports wl1273) Chip supports bluetooth transmit/recieve and fm radio functions through the same antenna, but is not enabled in software drivers. Connectivity: 802.11b/g/n Security: WEP/WPA/WPA2/802.1x Mode: Infrastructure
  • Audio: Ti TLV320DAC3100 Codec 3.5mm Headset Jack (TRS 3-Pole) - no mic input Single Rear Speaker PWM Headphone Amp Headphone Detection Mic Amp and ADC (Mic input not available) Audio Formats: .3GP, .3G2, .MP4, .AMR, .MP3, .MID, .XMF, .MXMF, .RTTL, .OTA, .IMY, .WAV, .OGG, .ACC ** Audio Codecs: ACC, ACC+, AMR, MP3, MIDI, LPCM **
  • Power Management: Texas Instruments TPS65921 PMIC Integrated Power Management IC with 3 DC/DC's, 4 LDO's, USB HS Transceiver
  • Battery: "Barnes & Noble" labeled 3.7V 4000mAh 14.8Wh Li-ion battery Battery Life: ~8 hours
  • Physical Specifications Dimensions: 8.1" (205mm) L x 5" (127mm) W x 0.48" (12.2mm) D Weight: ~15.8oz (~422g)
  • Micro-B USB 2.0 High-Speed
  • Accelerometer
  • Input Virtual QWERTY Keyboard On-Screen Soft-Keys ** 'n' Home button Power\Lock button Volume Up\Down buttons
Status
