Internal SD Card Won't Mount
Discussion in 'Android Tablet Q&A' started by eaking007, Apr 3, 2013.
  1. eaking007
    eaking007 Member
    Manila Philippines
    Coby Kyros MID7048-4
    I have a problem... IM USING COBY KYROS MID7048 ROOTED (I THINK VIRUSED)
    my internal sd card wont mount
    i cant see it settings- storage
    in ES FILE EXPLORER it says "SDCARD EMPTY UNMOUNTER OR NOT PRESENT"
    im afraid of messing of vold.fstab they said it may work but im afraid because i read i forum exactly my problem Traveller101 says do not mess up with vold.fstab especially telechips
    Can Someonehelp me!
  2. vampirefo.
    vampirefo. Senior Member Developer
    Huntington WV
    Leagoo Lead 1 ZTE OPEN C, Coby 7065, Coby 8042, Coby 9740
    several users have this problem, many of them caused their problem by editing the vold file, as of today there is no known fix. I don't own this device so can't debug it and find out where and what the problem is, if you search you will find severals users with the same problem.
    • Like Like x 2
  3. eaking007
    eaking007 Member
    Manila Philippines
    i see... now crying like hell..
    i know i only did this before its happen
    1.i dowload boot animation changer
    2.i download boot animation and use it.
    3. i reboot it (tablet)
    4.(the boot i download is jellybean) its stucks at start
    maybe thats the problem...
  4. bucolic2013
    bucolic2013 Member
    coby kyros MID8048
    i have a problem with regard to my sd card too. i am using a coby kyros mid8048. when i open the tablet ( turn it on) it still says that sd card is mounted but when i try to use the cam or try to downlad apps it would say insert sd card. please help. i forgot to mention that prior to this incident i lost all my apps which i transferred from the tablet to the sd card after i shut the tablet down. by the way, my sd card is transcend microSDHC class 4 32 gb.
  5. parham
    parham Member
    iran
    coby
    Its my y problem too i have a coby 8048
  6. RiyoRitsu
    RiyoRitsu Member
    Mabuhay, Mamtid, Cabuyao, Laguna, Philippines
    Coby Kyros mid8048
    i got that problem too but i think i solved it by:
    1. go to cwm
    2. got to mount/storage
    3. mount sdcard
    4. reboot
    thats the way i think i fixed it? (my sd card is transcend 1gb)
  7. sayefhussain
    sayefhussain Member
    Karachi, Pakistan
    Ainol Hero II 10 inch
    Some people say, some tablets have the problem recognizing 32GB SD card, though all the tablets today claim that they can read up to 32 GB cards. Try to use a smaller capacity card (like 16 GB) and then let us know.
  8. shinta
    shinta Member
    Philippines
    Coby Kyros MID8048
    Sir RiyoRitsu, I have bought a coby kyros mid8048 for about 3 weeks now and suddenly I'm having a problem with the sd card. It says it's mounted but when I tried to open the gallery and camera it says "No Storage, No external Memory available". Then I stumbled in your post but my problem is I don't know how to go into cwm, could you give a step by step procedure if you don't mind? My tablet has not been rooted cause I'm affraid to do so.
  9. eaking007
    eaking007 Member
    Manila Philippines
    will this work on MID7048
    KAMUSTA MGA KABABAYAN
  10. eaking007
    eaking007 Member
    Manila Philippines
    NAAHH got 1gb ext sd
  11. babyAMA
    babyAMA Member
    philippines
    coby mid8048
    same problem with my coby mid8048...
    Sir how can i got to cmw?
  12. babyAMA
    babyAMA Member
    philippines
    coby mid8048
    same problem with my coby mid8048...not rooted i want to root it how?
  13. GioFrie
    GioFrie Member
    Philippines
    Coby Kyros MID-8048
    press power button + volume down when booting to go to recovery mode...
  14. Kuman
    Kuman Senior Member
    Toronto
    iView TPC910
    When in recovery how do u go between the options, only the first, reboot, is selected, can't move to the next?
  15. tpaine
    tpaine Senior Member
    Socal
    Coby 7042, Coby 8065, Lenovo A2109
    Check this thread.
    http://www.androidtablets.net/forum...ixed-internal-storage-unmounted-8048-a-2.html
android internal storage not mounted
how to mount internal sd card
how to mount internal sd card android
internal sd card not mounting
internal sd card not mounting android
internal sd card not mounting android tablet
internal storage not mounting
internal storage not mounting android
my internal sd card is not mounting
