I move my data using WIFI and today I noticed that if I connect the NC to my PC it just makes device connected sound but it will not mount the internal storages. I have auto mount enabled Any idea what I'm doing wrong ? Thanks
you need to enable both the PC to take the connection, and the device to make the connection. did you do both?
Not sure where, didn't get any pop up like I do with my phone I just made sure that Auto mount in Nook Tools is enabled
Re-install adb usb drivers. [DRIVER PACK] Easy USB ADB Installer for Windows (32/64 bit) - xda-developers
I tried that before but it didn't help. When I plug in the USB cord I can see 2 other removable storage drives in Device manage but they are not mounted There is also new WPD FileSystem driver but i's marked with yellow triangle with exclamation point.
hehe, it didn't occurred to me since any other device ( G-TAB or Desire phone) just gives me pop-up asking what to do
Me too, waiting patiently. No I'm no chief, just a happy appreciative to others, rooter/custom rom user.
