Kyros 7015 Soldered battery/Irreplaceable after 300 charges?
Discussion in 'Coby Generation 1' started by newtoandroid, Mar 21, 2011.
  1. newtoandroid
    newtoandroid Member
    Washington, DC
    Coby Kyros MID 7015
    Hello,
    I just bought a Coby Kyros 7015. A review on Amazon stated the battery is "soldered" and that it would die after 300 charges and has no replacement option.
    Has anyone else heard of this or know if it is true?
  2. l_n
    l_n Senior Member
    TN, USA
    Mid7015
    Li-poly batteries wil start to decay after approx. 300 charge cycles. If you google lithium polymer batteries, you should be able to find some decent articles about it.
  3. psphacker06
    psphacker06 Member
    Maine
    KYROS 7015
    And this is why I got a 3 year warranty from squaretrade.
    Sent from my MID7015A using Tapatalk
  4. kerry_s
    kerry_s Member
    Here
    coby mid7015
    I would try to replace it when the time comes. I'll most likely be getting something new by then though. Only time will tell.
  5. tipstir
    USA
    COBY KYROS 7015 | 7015A
    Coby 7005 had this same issue. Oh well I don't expect these tablets to last so long, maybe one to two years on some.
  6. n9ots
    n9ots Member
    Spring Hill, Fl
    Coby 7015-4G
    As long as there is away to open this beasty then the battery can be replaced.
  7. Spider
    Chicago, IL
coby battery
coby kyros 7015 battery
coby kyros battery replacement
coby kyros mid 7015 battery
coby kyros tablet battery replacement
coby tablet battery
coby tablet battery replacement
colby kros
kyros mid7012 take out battery
replace batteries in coby kyros
