Lenovo A2109 Boots Up and Goes to Booting Android Recovery and Nothing Else
Discussion in 'Lenovo IdeaTab A2109 Technical' started by Frybob, Apr 3, 2014.
  1. Frybob
    Frybob Junior Member
    My tablet was running kind of sluggish the other day so I rebooted like I have done many times.
    This time it booted and said booting android recovery. It now does this every time I reboot. I have tried doing a wipe data/factory reset and wipe cache. I can't get it to boot into fastboot by holding down the vol - button and pressing power. I'm at my whits end. Can anyone tell me how to fix this. I can connect to my pc via adb though.
    Thanks,
    Bob
  2. mcl630
    mcl630 Senior Member
    Illinois, USA
    Lenovo IdeaTab A2109A, Archos A101IT
    Try reinstalling whatever ROM you're running in recovery.
  3. Frybob
    I've tried that via the sd card as I can't get the tablet to boot to the fastboot screen. I haven't been able to get any roms to load.
  4. mcl630
    Illinois, USA
    If you can get into recovery, you should be able to install a ROM from there. If you install the stock 4.1.1 ROM, that should reinstall the fastboot bootloader.
  5. Frybob
    Yep, I just did that but the problem still persists. I get the rom installed and reboot and it boots right back to the android recovery screen.
  6. xdrc45
    xdrc45 Member
    Great White, MI
    Lenovo A2109 ~ Custom Rom ~ Flashes ~ *PAC Combo Rom* Prestige Pro 7D ~ TWRP 2.7
    You might also want to try reinstalling CWM recovery, just in case that it may have become corrupted.
    That happened to me on one of my devices.
    Did you install the actual Lenovo stock ROM or did you install a custom stock ROM like mcl630 stock debloated ROM?
  7. Frybob
    I installed the stock rom. I'm not sure how to install the CWM recovery as I'm not able to get into fastboot. Any ideas?
  8. xdrc45
    xdrc45 Member
    Great White, MI
    Do you still have adb access? Try booting to the bootloader/fastboot with adb... "adb reboot bootloader"
    If it sticks then fastboot flash recovery.img
  9. Frybob
    I just tried that and it starts it get and error message and then it says closed. Please see the screen shot below.
  10. vampirefo.
    vampirefo. Senior Member Developer
    Huntington WV
    Leagoo Lead 1 ZTE OPEN C, Coby 7065, Coby 8042, Coby 9740
    adb shell
    busybox df -h
    post output.
    Sent from my DK C30 Android Phone
  11. Frybob
    It goes right to error: closed right after entering adb shell.
  12. vampirefo.
    Huntington WV
    So you can't adb.
    Sent from my DARKMOON DK C30
dk c30 bootloader
dk c30 lenovo bootloader
factory reset lenovo ideatab android penguin
fryvbob
lenovo boot recovery android
lenovo boot to recovery android
lenovo ideatab a2109 boot image
lenovo ideatab a2109 sd card boot
lenovo tablet boots to recovery
root a2109 tablet
