Links to files Coby Kyros 1125 Firmware,Flash,IMG etc
Discussion in 'Coby Generation 2 Development' started by FormatCdrive, Sep 26, 2012.
  1. FormatCdrive
    FormatCdrive Senior Member
    NULL
    Here are all the links to files i have found related to kyros 1125 images, firmware, flash etc I have used all files,
    so should work on 1125 ok.
    Mid1125.ZIP GB2.3.3 --- lk.rom / m801_mtds.img / readme.txt / manual.pdf
    MID1125.rar - 4shared.com - online file sharing and storage - download
    Gapps-ics-20120429-signed.zip --- signed google apps framework.apks etc
    http://c-mav-android.googlecode.com/files/gapps-ics-20120429-signed.zip
    Superuser 2.3.6.1 .zip
    http://dl.dropbox.com/u/6408470/su-releases/su-2.3.6.1-ef-signed.zip
    Huawei unlock software,drivers em770w 3G card in coby 1125 /
    if you need it coby 3G dosent need updating ,
    it has latest firmware i got this because i took my 3G card out and tested it on my motion tablet pc and it works great.
    Huawei Unlocking: Huawei EM770 unlock software Firmware update download
    Android tweaks and Hacks website i found.
    Android tweak and hack | smartphone and tablet review, tips,tweak and hack
    QuikIMG XDA developers flash software.
    [TOOL][FASTBOOT] QuikIMG - A frontend for fastboot [0.2 beta][22 Mar] - xda-developers
    Formula1 New.zip Zach Bolt files use recoverytools.apk then CWM menu to install zips / read the readme first
    Formula1 New.zip - 4shared.com - online file sharing and storage - download - Zach Bolt
    adb fastboot and other tools / android sdk tools
    http://dottech.org/uploads/adb_fastboot_and_other_tools.zip
    fastboot.zip / sdk same as above but with LGunitedMobileDriver USB
    Fastboot.zip
    1125_3g.zip GB2.3.3 didnt use just found in below xda post
    http://kaosmad.com/android/mid1125/1125-3g.zip
    XDA developer post show you how to use FWDN
    [Q] Coby Kyros Mid1125-4G stock ROM - xda-developers
    ADB drivers didnt work on my XP , but might for you.
    ADB Drivers | Coby Kyros MID Tablets
    AndroidForum link page to stock fastboot recovery.img / CWM v4.img / CWM V5.img
    MID7127 Recovery.img's (Stock, CWM & KTZ) - Android Forums
    XDA developers links didnt use this but it useful ADB / flash Mode / Fastboot download drivers
    [Download] ADB + Flash Mode + Fastboot Drivers - xda-developers
    link to androidtablets patch 1125_v2.zip didnt use but useful anyway
    http://www.androidtablets.net/forum...ve-your-coby-kyros-1125-frozen-logo-coby.html
    recoverystock img.zip fastboot img file
    http://www.e-world-everywhere.net/Newsblog/wp-content/uploads/2011/12/recoverystock.img_.zip
    how to install fastboot adb sdk android
    [Android] Downloads links for USB (adb and fastboot) drivers for Windows for all Android phones and tablets | dotTech
    PDANet 32 bit USB android drivers, these worked for me. but it does install a pdanet network software ,
    just uninstall this pdanet software. you will need these drivers for adb in windows, for fastboot and adb commands.
    How to Install ADB Driver via PDAnet software | www.topnotchtablets.com
    superuser 3.0.7 zip file
    http://downloads.androidsu.com/superuser/Superuser-3.0.7-efghi-signed.zip
    filecrop search Kyros some used some not
    Coby Kyros 1125 - Download
    Coby Mid1125-seed-0009.zip kyros 1125 non 3g ics 4.0.1 image /
    use CWM restore function from sd card to use these files.
    coby_mid1125-seed-0009.zip
    images.rar boot.img system.img cache.img recovery.img data.img nandroid.md5 used these with fastboot.
    images.rar download - 2shared
    superoneclick cNet page root access apparently, didnt work on my pc.
    Thank you for downloading SuperOneClick from CNET Download.com
    SD Formatter.zip didnt use but useful link
    SDFormatterv3.0.zip
    FWDN v&_v2.13.zip firmware flash tool use at own risk.
    灵韵先锋升级工具FWDN_V7_v2.13.rar
    How to use fastboot / connect to pc in adb developement mode /
    reset tablet hold down volume down button. fastboot mode. go to command prompt ,
    navigate to android sdk / tools directory.
    type fastboot flash boot boot.img or fastboot flash recovery recovery.img or
    fastboot flash system system.img or fastboot flashall
    How to use adb / connect to pc in adb mode go to command prompt , navigate to android sdk /
    tools directory. type adb reboot recovery , this will reboot tablet to recovery mode ,
    if you have CWM recovery.img , use menu to backup/restore from SD card.
    How to use FWDN / install usb drivers from zip / reset tablet hold up volume button ,
    FWDN mode. select lk.rom and .img file press start to image tablet.
    files i used from mid1125.rar lk.rom and m801_mtd.img
    USE AT OWN RISK , VOID WARRANTY LOL , DONT BLAME ME IF IT BRICKS. Have a nice day. [​IMG]
    • Like Like x 2
  2. renderay78
    renderay78 Member
    ou tell me who is a better rom for MID 1125 on all files you have post please
  3. FormatCdrive
    NULL
    the best rom is top file mid1125.zip this is GB 2.3.3 this worked on my 1125 3g, should work on 1125 non 3g
    only problem found is nand partition fault, still come up with error.
    this fault stops the internal sdcard partition being seen.
    im looking for a fix now.
    but everything else works fine with this image.
  4. Dunkelwerker
    Dunkelwerker Member
    Germany
    Coby Kyros 1125
    Coby mid1125:
    is it possible to change the size of the internal partitions ?
  5. renderay78
    renderay78 Member
    is the Wifi work for you ? for me not ....
  6. FormatCdrive
    NULL
  7. FormatCdrive
    NULL
    yeah it did work for me, i did upgrade to 4.1.1 over wifi.
    the 1125 seems to have really bad wifi , i had the 1125 right next to the AP box and it still had low bars on wifi.
    in 4.1.1 there is an option which disables wifi connection if signal bad. i dont think 2.3.3 had this option.
    i have even opened up my 1125 the wifi wire stretches to the top of the tablet (end without buttons)
    you could try holding the tablet in portrait mode , this might make the signal better.
    the 3g signal is bad too, had to find a longer wire and leave it dangling outside the tablet, until i find a fix.
  8. renderay78
    renderay78 Member
    Wifi don't want to turn on ... it tell me error ... what did you think about this probleme ?
coby firmware download
coby kyros 1125 3g not work
coby kyros 1125-3g stock
coby kyros mid1125 firmware
coby kyros mid1125 firmware download
coby kyros mid1125 firmware update
coby kyros mid1125 rom
coby kyros mid1125 software update
mid1125 firmware
mid1125 rom
