How to get these files to your device:
unzip the file to where you have adb at
adb push install-recovery.sh /data/local/tmp/install-recovery.sh
adb push CW_recovery.img /data/local/tmp/CW_recovery.img
adb shell
su
busybox mount -o remount,rw /system
exit
exit
adb push reboot-recovery /system/bin/reboot-recovery
adb shell
su
chmod 755 /system/bin/reboot-recovery
chmod 777 /data/local/tmp/install-recovery.sh
your device should now reboot into cwm-recovery.
to navigate use the volume up and down, power to select, back to go back
navigate to backup and restore and perform a backup
reboot the tablet.
now go to this link and download gapps and put it onto your sd card
20120429
open up adb
adb shell
su
reboot-recovery
You should now be back into cwm-recovery.
Navigate to install zip from sdcard, choose zip from sdcard and select your gapps zip and install it, now reboot your device once its finished. You should now have gapps, but you will be limited to the apps you can download until we get your build.prop updated to fool the market into thinking you have a compatible device.
now go back to adb
adb shell
su
reboot-recovery
do another backup if everything is working right.
adb shell
su
exit
exit
adb shell
su
reboot the tablet.
20120429
open up adb
adb shell
su
reboot-recovery
now go back to adb
adb shell
su
reboot-recovery
