Looking for help
Kingster
Have problem with starting my Binatone HomeSurf Tablet 7.
When I turn it ON,on screen appears ANDROID Starting... ,and it remains all the time,sometimes it restarts it self.
It happened when I plugged in memory card,maybe it was infected or something,and when I removed it from slot problem was still there.
Spider
15,785
1,813
Hi Kingster, congratulations on your new Binatone tablet and welcome to the forum. Nice to have you as a member of Android Tablets. I'm moving your thread to the Android Tablet Q&A section for you, where more people are likely to join the discussion and try to help you. Good luck!
Kingster
I looked once before users manual,but without any good results.I need something more,but tnx anyway. :D
Spider
15,785
1,813
If it's not getting past the Android screen, you probably need to do a reset of the tablet. Doing so will delete everything on the tablet, and restore it to the way it was when you first got it. I'm not familiar with your tablet, but the following works for many different tablets.
Make sure the tablet is OFF.
Press and hold the Volume Up and Power buttons at the same time.
When the Android starts to flash, release the buttons.
Then try to press different hardware buttons until you are given a list of options.
(If Volume Up and Power doesn't work, try Volume Down and Power.)
Kingster
I tried everything u told me,but from some reason there is no way that I could open some kind of category with some options.I even looked for a tinny hole on it.Found one and I put a needle there but also with NO results. :confused:
