Yes I do.. I did! You need to wipe out the partition though a couple of factory resets wipe the cache prior to wipe the partition though. Just don't change anything in the OEM ROM just upgrade as is. If you do that you'll kill off ClockWork Mod. Trade off. I've made so many backups. But I doing and experiment. Frankly everything works no FC. I trying to see if I can just build ROM clean free for FC, glitches and stuff. I would like to get my HoneyComb at 100%. We have ammo just have to implement it. My task bar looks so great but like I had wanted just to make a quick patch so everyone can use HoneyComb on any ROM build. OEM, Rooted or Non-Rooted.
Too much left over code from everything on the tablet poor wipe method. NAND doesn't get 100% removed of the junk. Mirror images are left behind. The only to do it go under SDK and remove the junk. This junk get's all twisted with all these ROMs Then those errors on the screen. Funny how Gallery should work but never did. Under OEM you don't have these issues. Though 200 LCD is too big I can set it back 240. Trade off is the screen isn't as sharp.
Anyway I can still drop GE on it without using an update.zip, but you know that GE slows the tablet down uses a lot of RAM. The new Coby the 7024 has enough RAM to run everything. I might look at that until the price comes down some more. 1GHz I bet that runs at 800MHz to cut down on the battery.
lol, you have some of the thoughts i had when i tried your honeycomb.
i ended up blowing it all away, did the root, recovery & market. i grabbed the honeycomb wallpapers from market. i added ad block list(mvp) to the /etc/hosts file, then i backed it all up right there. haven't decided what else i'll add yet, but i'm sticking with only free stuff.
