Hi everyone, Here's some tips of what you can do to make your life easier with busybox. As the wikipedia page says: There is a good version of busybox that can be downloaded using Titanium Backup. Or from their site you can download it from their site here. More information on how to install it can be found at the titanium back up troubleshooting faq. Anyway, lets say we've got busybox installed. Now to get a list of all of the commands just type busybox and press enter (this is via adb shell) and you'll be presented with all of the commands built into busybox. To run one of these commands, we'd normally type: busybox <command> where command is the command you wish to run. Now it gets tedious having to type busybox before every command. But there is a solution! First we need to mount system read write with the following command: mount -o rw,remount -t yaffs2 /dev/block/mtdblock1 /system now we need to change to the system/bin directory (bin is where all our command line applications and commands live.) Using the command ln (link) we can create softlinks to the busybox binary with the name of the command we wish to run. Busybox recognises this and will run the correct command. So for example tar. We'd need to run the following command: ln -s busybox tar now we can just type tar instead of having to type busybox tar. Now we can repeat this for any of the other missing commands, and once you're done remember to mount system back to read only with: mount -o ro,remount -t yaffs2 /dev/block/mtdblock1 /system Hope this helps some people out. Remember to have fun. ~Ivy
