Market download problems
alimag
7
Hi,
Is it just me or some of you also have problems downloading apps from the market?
To be sure, I reinstalled everything from the Coby update, clockwork recovery mod to the market zip.
For every file I want to download I have to go to Applications -> Market, clear the cache and uninstall the updates, then check in Services if the download manager is working and if so force stop it.
If I dont do that, I stay stuck in download mode (Ongoing...) forever.
Is there anyone facing the same problem?
Thanks in advance
Cheers
alimag
7
Hi,
After further testing I realized that the problem is probably from my router. The market is working perfectly everywhere else.
The funny thing is that it was working before. I guess my old dlink did not like the last market update. Time for a new router...
@hdectablet
Thanks for taking the time to answer.
Cheers
