Meiying M11 - using and storing onto the microSD?
Discussion in 'Rockchip RK2918 Tablets' started by ChromeCat, Jan 9, 2012.
  1. ChromeCat
    ChromeCat Member
    USA
    HTC Inspire phone, Meiying Phantom M11 tablet
    Dear friends,
    I put a microSD card and can't figure out how to use it!!
    I am trying to put a movie onto the card.
    Initially I hooked up my tablet via USB/microUSB wire. It opened on my PC and some files were in English, others were in Chinese. I saw a folder: SD Card so I copied my movie from my PC to that folder. I then unhooked the tablet from the PC and couldn't figure out how to access the microSD card from the tablet at all!
    I looked in videos icon of the tablet just to see if it was there but it wasn't.
    So then I hooked the tablet to the PC again and just copied the movie from PC to M11 to see where it would go / what would happen. I was able to find it in with the other videos. However, I still don't find a way to get it to the microSD card. Or to access the microSD card at all.
    I don't care which route I have to take, I just want to be able to get the movies onto the microSD.
    Additionally, when I insert my USB flash drive, I can find files simply by browsing the tablet, not by going into the USB chip.
    Also, is there a way to delete the four previews that are pre-installed in this tablet?
    Thank you so very much!!
