Menu button problem
JohanMeert
Since there is no phyical menu button, i'm having trouble getting into the "setup" of "preferences" of most programs. For example I installed Quickpic viewer and want to sort my photo's by name but cannot find where to do it.
Anybody know how to do this ?
probbiethe1
Super Moderator
1,838
139
if your just looking for a menu button try "button savior" but for the quickpic viewer i dont know
beegee_tokyo
Developer
Feb 8, 2011
72
Button savior to get on screen buttons, it is a great solution to get access to menu in full screen apps.
In Quickpic open an album, then press menu (in button savior or in taskbar) then select sort by.
Quickpic shows the top bar, why do you not use the menu button in the top bar?
