Modding Launcher2.apk using apktool
Discussion in 'Coby Generation 2 Technical' started by lfom, Oct 16, 2011.
  1. lfom
    lfom Senior Member Developer
    Brasil
    I have downloaded and installed apktool trying to mod stock Launcher to show 5x5 icons, then I installed framework-res.apk. I was able to unpack, edit the XML files needed (at least I think so lol) and rebuild Launcher2.apk, but when I try to used it it never loads. Any tips? Thanks
  2. Vernox701
    Vernox701 Member
    Nevada
    Coby mid8024,Coby mid1024
    you either need to re-sign it or use the original apk and open it using 7zip and drop in the changed files....ppcgeeks has a apk signer
  3. lfom
    Brasil
    I thought it'd be already signed since I have unpacked the original apk... I will try signing it, thanks!
  4. nefirim
    nefirim Senior Member Developer
    Coby Kyros 8024
    you might want to look into Apk manager, its a script that uses apktool to decompile APKs but will also can be used to sign apks once they're compiled again
  5. lfom
    Brasil
    Thank you, guys. This did the trick. I've used ZipSigner 2 with "auto-testkey", it's the correct setting?
    I could not install it over the old one, but deleting stock and copying, killed Launcher and it worked.
    Stock Gingerbread 2.3 Launcher with 5x5 Workspace:
    Launcher2 - Minus.com
  6. Vernox701
    Vernox701 Member
    Nevada
    glad you got it
  7. lfom
    Brasil
    Anyone tested the Launcher in the stock Gingerbread theme? All icons are rotated normally when you go from landscape to portrait and vice-versa?
    This doesn't work in the HC theme Launcher: I can display as many icons as I want but as soon as I rotate the tablet, only the first 4x4 icons stay, all others vanish... Any ideas?
  8. Pickupman66
    Pickupman66 Member
    Tennessee
    Samsung Captivate (Rooted) Coby Kyros 1024
    Ill give it a shot. I am on stock theme
    Sent from my SAMSUNG-SGH-I897 using Tapatalk
  9. Pickupman66
    Pickupman66 Member
    Tennessee
    so... my kyros didnt like just swapping out the Launcher2.apk like that. it locked up on me with a black screen and I had to reset it. then it would not load past the boot animation. took FOREVER!>!>!! like over 2 mins. so....
    I swapped it out in the firmware packet, and then reloaded it. also threw in some Titanium backup apk, the latest market and now...so far, it works well. I get 5 across apps both directions when I turn the screen....
    Edit.. I lied. that 5th row vanishes. also, dont put any below them either.. they vanish too....
    that said, I do like the fact that they are tighter together. looks better.. just some extra space on the backgrounds.
  10. lfom
    Brasil
    Thanks! So it doesn't work (extra icons vanish), right? Then I think it's not useful, too bad... =(
  11. Pickupman66
    Pickupman66 Member
    Tennessee
    Nope. But it still makes them closer together....
    Sent from my rooted, baked, Gingerbread rocking Kyros MID1024
apktool gingerbread
cara edit launcher2
edit launcher with apktool
edit launcher2
how edit launcher2
how to edit launcher2 using apk
launcher 2 apk
launcher2
launcher2 andromax mod
launcher2 apk
launcher2 apk moto e
launcher2 mod
launcher2 mod apk
launcher2 no tab
launcher2 transparan
launcher2apk
modding transparan launcher2
modify launcher2 apk
motoe launcher2 edit
stock launcher for android apk
